iOptron ZEQ25, initial impressions
#426
Posted 22 September 2013 - 02:11 PM
Clear Skies, RandyC
http://www.flickr.co...s/galaxygardens
#427
Posted 22 September 2013 - 03:27 PM
tonight I was doing some in-house testing with the mount when I found out a bad surprise.
After turning on the mount I simulated a slew to Kochab, then the movement stopped and the mount started tracking.
The bad thing was that the motors made an awful noise because the normal tracking sound was mixed with the crosstalk noise.
I tried to stop the crosstalk by quickly pushing the directional buttons but to my surprise I found out that the noise was coming from both motors and it was almost impossible to identify if and when the crosstalk had stopped from which motor.
I had to stop the tracking and after a lot of trying I managed to stop the crosstalk too.
One time I couldn't even stop the crosstalk noise at all and I had to turn off the mount!
I'm afraid this is something that seriously affects the correct use of the mount, can you imagine all this mess during a photo session?
What should I do now? Should I contact the support? Should I return the mount? Does anybody have any advice on how to handle this problem?
Thanks.
Piero
#428
Posted 22 September 2013 - 03:56 PM
I think I'd contact iOptron customer support as soon as possible. You may get a answer here but it won't hurt to have iOptron weigh in on the issue also.
#429
Posted 22 September 2013 - 05:50 PM
And this is the "home made" extension shaft.
This looks identical to the extension bar for ZEQ25 at ioptron web site, under the accessories/counterweight. part # 7126.
Dimensions:
Diameter: 20mm
Net Length: 7.25 inches
Length (including threads): 7.75 inches
#430
Posted 22 September 2013 - 06:07 PM
That would (will) definitely ruin a photo session. Not a big problem if a stab at the #2 slew button stops it, but if it won't stop, you're stuck with viewing visually, and putting up with a lot of annoying noise to boot.
Attached is a screen shot of the crosstalk when it occurs during guiding, in this case it was coming from the DEC motor.
Contact iOptron, they're probably working on a fix..
Paul
#431
Posted 22 September 2013 - 06:23 PM
Heinz
#432
Posted 22 September 2013 - 07:13 PM
Paul
Being new to AP, and with my ZEQ arriving WED, I am now worried. Not because I'm afraid of getting a one off, but more so because I don't think I'd know if i did have one. What is this cross talk ive seen mentioned a few times?
#433
Posted 22 September 2013 - 08:21 PM
Don't worry too much! Everyone I've seen that had any problem with their z25 ended up having the problem fixed. Worse case I've seen is having to exchange the mount. Most problems have been fixed with a little input from users here or on the Yahoo iOptron group or through iOptron's excellent customer service. If you had paid $2,000 for a new mount, you wouldn't still be running a risk of an initial problem. I guess that the more you pay the less likely problems are but they can come up even on a $10,000 mount.
Posted 22 September 2013 - 08:34 PM
#435
Posted 22 September 2013 - 11:27 PM
On a side note. Just got a new OTA for longer focal length imaging to go along with my AT72ed, a F4.8 152mm ES mak Newtonian (total imaging weight on the mount about 20lbs) and the PHD graph is the same as with my 72ed. Not sure it's even perfectly balanced being a Newtonian with the focuser a bit to the side. Really looks like you can get the full mount capacity while imaging with this mount instead of the 1/2 2/3 rule.
#436
Posted 23 September 2013 - 01:43 AM
I just sent iOptron support an email describing the problem, let's see what they come up with.
I'll keep you posted.
Ciao.
Piero
#437
Posted 23 September 2013 - 02:26 AM
Is your new MakNewt the Comet Catcher? That is a sweet looking OTA. Let us know how you like it. I'm waiting on a 125mm F/3.8 Schmidt Newt that should be in next week.
Posted 23 September 2013 - 05:34 AM
#439
Posted 23 September 2013 - 08:54 AM
That is absolutely correct based on my experience with the "Z-Balanced" design. You can take all the pre-conceived notions we grew up with over the years, and toss them out the window.
This mount's payload capacity is actually a bit under-rated from the factory. The RA and DEC boards are marked 'EQ28', so iOptron has already dropped the design capacity one pound, probably to minimize competition with it's excellent iEQ30 GEM mount.
You cannot compare a GEM to a CEM. CEM = Chinese Equatorial Mount. Future mounts of this design, will probably be marketed with the 'CEM' description, it's just a better solution all around.
I think if I filled my AT10RC with concrete, with sufficient counterweights, the mount would still function as long as the loads were balanced.....
Just my humble opinion,
Paul
#440
Posted 23 September 2013 - 12:23 PM
#441
Posted 23 September 2013 - 02:48 PM
#442
Posted 23 September 2013 - 03:21 PM
#443
Posted 24 September 2013 - 12:14 PM
This OTA, which I am expecting in October, is at the limit of the load capacity of the ZEQ25. Still, I am hoping to do some AP with this combo. Do you think this is realistic, or should I rather wait for a more beefy version of the ZEQ25?
I find the ZEQ25 attractive, because it is still train portable, if necessary. That's why I would actually prefer not to use a heavier mount, if possible.
But in this case I might use the 2" tripod instead of the 1.5". Do you think the 2" tripod would make a noticeable difference for visual and/or imaging? The 1.5" tripod appears to me rather sturdy already. But this is difficult for me to judge, because I have no experience with neither the Mewlon 250 nor AP.
Heinz
P.s. We have already reached page 23. This must be one of the most active, lively and enduring threads of all time. Congratulations, Paul.
#444
Posted 24 September 2013 - 01:21 PM
It's realistic Heinz, and for train portability, it's excellent. The 2" tripod will add some stiffness, and allow easier access to the polar scope due to its increased height, but at a weight and size penalty.
A 'more beefy' version will probably appear before December, but I'm sure it will not be as portable, and convenient to use as the ZEQ25.
I'm figuring the next iteration will be in the 25 pound range, just for the mount? With tripod and counterweights, that would be a hassle on a train for sure.
Page 23? No, I think one of the longest was on the iEQ45 when it intro'd, now that was a long thread....
All the best,
Paul
#445
Posted 24 September 2013 - 01:38 PM
Clear skies are in the forecast.
How accurate is polar allignment through the polar scope with one star alignment? I'd love to take some quick exposure just to test it out. would 30-60 seconds be reasonable if the alignment is good?
I've been reading the instruction book and it seems the polar alignment section is leaving out a few pieces.
I am a little confused about the return your scope to zero part.
Also, I imagine an illuminated reticle would probably aid in a more exact polar alignment during the one star allignment portion?
How much refinement is usually needed after this for an accurate polar allignment?
I've never had a GEM, or CEM as is it, before. I've also never had to accuratley polar allign.
#446
Posted 24 September 2013 - 02:14 PM
And how about wind? The OTA is rather extended. Any experiences or opinions here?
When all equipment has arrived and has been mounted, I will thus probably have three ZEQ25! World record so far?
Have a good week.
Heinz
#447
Posted 24 September 2013 - 04:08 PM
Can you used the tripod without the legs extended or extended very little? I haven't had any problems with the 1.5" legs but I keep it retracted just about all the way. But my hardware is only about 15kg.
If the mount is going to work with your kit, I'd want the 2" legs. I assume you have to buy it as a second tripod? If so, give it a go with the current one and see how it does. I'll be interested in how you do with that much weight and focal length. Keep us posted.
Posted 24 September 2013 - 04:29 PM
I'm writing this to let you know of a potential small issue with the mount if accidently hit with the drives locked. Might not be an issue for most people as they are not as great a klutz as myself.
On a "positive" note since I was taking 5 minute frames every other frame was near perfect.
#449
Posted 24 September 2013 - 05:22 PM
I get mine tomorrow.....
Hi Sean,
I've had my ZEQ25-GT for a couple of months now but have only been able to get it out a few times - I can't seem to convince the clouds to stay away!
Anyway, you should expect to get within 0.1 degree of NCP using the polar scope. You only need to use the polar scope alignment procedure if you have a view of the Pole star. If you are not using an auto-guider you should get reasonable results from 30 second exposures using your AT65EDQ which has a focal length of 420mm. Be aware that the ZEQ25 does not have a specified maximum Periodic Error - I have only seen PE results after guiding which are very good and the word from iOptron support is that there was no designed maximum PE rating. I have measured mine using PECPREP and found it to be about 65 arc seconds peak to peak. Even with that, 30 second exposures with 420mm should be okay. If, however, you plan to use an auto-guider, you should expect the PE to drop below 8 arc seconds. Paul has a few screen shots and a YouTube video of his mount doing just that while guiding with PHD.
If you are the recipient of a good sample you will be less restrained by PE and your unguided images may benefit from better polar alignment - this is where learning how to drift align your mount will help.
Good luck and clear skies,
Hunlon.
