I said regardless scopes because sometimes members keep saying "I love this eyepiece, it is shining in all or most of my scopes", so that i asked as if there is one model of each version that can stand out in many scopes, not necessary to shine in all, but i don't know if there is an eyepiece that is a joy to be use in different scopes.
It depends on the focal ratio and focal length differences between scopes. Some eyepieces are just too much magnification / too little exit pupil for some scopes, but are fine in others.
I have a 3mm eyepiece for my 12" F/5 dob at 1525mm, but I would never use that same eyepiece in a 16" F/10 SCT with a 4000mm focal length. Way too much magnification and way too small of an exit pupil.
Some eyepieces work well in fast focal ratios and slow focal ratios, other eyepieces only work well in slow focal ratios. Often when people say the eyepiece works well in all of their scopes they mean:
1. It has sufficient edge correction that it works well at slow and fast focal ratios
2. It has a modest focal length that is neither too much or too little magnification in all of their scopes
Forget about 180mm Mak, i have ST80, i ordered and still waiting my 8" Newtonian [F5], and maybe i buy another refractor better than ST80 and it will be an APO refractor, most likely maybe something of 60-70mm range, and in the future i am saving for Takahashi FSQ-106 no doubt, so i will have collection of scopes sooner or later, and most likely i will only focus on either very narrow high magnification or super wide field view, i won't focus much in the middle but i can think about that sometimes, and sounds wide eyepieces are in 25-40mm range.
Well with such a wide range of scopes, an eyepiece in one scope might give a wide field, low power view, but then another scope might give a high power, narrow field of view, and in yet another scope, it might give a medium power view.
Just do some basic math with say, a 10mm Ethos:
* 180mm Mak @ F/15 is 270x, 0.67mm exit pupil, 0.38 degree FOV - high power
* 8" Newt @ F/5 is 101x, 2mm exit pupil, and 1 degree FOV - modest power
* ST80 @ F/5 is 40x, 2mm exit pupil, and 2.54 degree FOV - low power
Three completely different views of the sky from the same eyepiece.
I was hoping if there is kind of a chart or a table of each brand of eyepieces, mentioning the type or version of eyepieces then in opposite it mentions which scopes are compatible or recommended for, for example, Tele Vue 13mm Ethos ---> recommended for 70-120mm refractor, 6-10" reflector and 6" Mak, or the opposite, some with current gear mentioning the scope then recommend which eyepiece for each brand if possible, such as: Celestron C11[standard of HD] -------> Televue Nagler 10T6/13T/18.... Ethos 12 and 14 up to 32mm, ES 82" 10/16/24/32,....etc
That does not exist. It's all a matter of preference and what your seeing conditions support.
Edited by CrazyPanda, 18 March 2018 - 12:24 PM.
