As a newbe to the world of cooled cameras, when a camera has the capability to cool to say 40 C below ambient (just an arbitrary figure) do you set a desired temperature in the software like I want the camera to actually be at 0 C or do you set the differential like I want to image at 20 C below ambient?
Question on cooling
#1
Posted 12 August 2019 - 06:16 PM
#2
Posted 12 August 2019 - 06:34 PM
You set desired temp. The software and the camera cooler will establish the set temp...IF it's not too warm to get that low.
In my case, I have to settle for -10°C, since it's so warm in southern MS that it can't reach -15°C. Even -12°C was pushing the cooler to 99%. I'll run cooler when the Sun Devil's nether regions cool off...
#3
Posted 12 August 2019 - 07:17 PM
By the way, cool it as far as it will conveniently go. If you can tell how much power it is using, cool it to 80-90 of the power rating. That gives you some leeway if some situation makes it want to heat up some.
Alex
