Hello all:
Looking for tips on what I could be doing wrong with a fairly new ASI294MM camera. I had several successful sessions imaging galaxies but hit a snag when trying narrowband for the first time. I tried the Owl Nebula as a simple target for experimenting with camera settings.
My Ha and OIII flats and lights seemed to turn out normal. I am using 3X3 binning, -10C, Unity gain settings of 120 and Offset 30. Camera is on a C925Edge with 0.7X FR. The problem occurs when trying to use my 12 nm Astronomik SII filter. My lights were 180s long, and flats were taken with my standard light panel I have been using for years now. The SII filter has worked with other mono cameras I have used in the past.
The individual light frames, 30K (8.78s) and 10K (2.34s) flat frames, and final flat master all show a very bright circular but diffuse disc in the frame center. Please see pics. Then when I go to calibrate and stack the final SII master light, there is a dark disc in the center. I have tried PixInsight WBPP 2.0 and also manually calibrating everything but the result is the same.
Any ideas? Haven't seen this issue before but I think it is with the camera or the camera settings. I should mention I have the latest ZWO drivers, so the cam has been unbinned from 4.63 to 2.3 microns. I am using 3x3 binning to get 0.87 arcsec/pixel for the 1645 mm FL.
Thanks much,
John
Edited by adastranova, 07 April 2021 - 12:34 AM.
