I have recently acquired a Bausch and Lomb Criterion 4000 SCT. I have posted in the Classics forum about this. However, i will post here about possible D.I.Y. modifications to the telescope.
I do not have a power lead for the telescope and the seller did not know if the motor works. I am in the UK. On the underside of the telescope is written 110 Vac 60 Hz. On the motor it says 110V 60Hz and 3W also .75
From the replies on the Classic forum I have understood what I could buy to get the correct AC power supplied to the telescope. However, where I live I can only see about a quarter of the sky from my terrace. I would therefore like to travel with the telescope. and be able to use a battery to power it. Also, the telescope is very old and I do not know if the wiring is safe to use.
I could get an inverter, however these are not that cheap and I have read that they do not always work that well.
I wondered if it would be possible to convert the telescope to use stepper motors, possibly with Onstep.? The current motor is a clock drive motor. Somewhere i have a Raspberry Pi and Arduino that I have never used. I also have some small motors packed away that are probably stepper motors, I will dig them out.
I have ordered some imperial Hex/Allen keys whcih I can hopefully use to take apart the telescope so I can see the gears that it uses.
I attach some picures of the telescope.
