Hi Folks;
Conditions were not really favorable tonight but its the first clearish night in several weeks since I mounted up the CDK so I decided to do some testing and experimenting to get the feel of the scope.
I'm using The Sky X and an MX+ mount and thought setting up for plate solving (image link in TSX terms) might be a good first task to go for. Of course, for that, you need decent focusing so that's where I started - with TSX's @focus3 autofocus tool. To use @focus3, I needed to first enter some data on: F-ratio, pixel size and focuser step size. I had previously asked the folks at Planewave about step size for the Hedrick Focuser that came with the scope, and was told to use 1.0 Micron. This approach didn't get me very far tonight so I increased it to 4.0, then 6.0 microns and finally completed the autofocus routine and the scope was in decent focus. Problem is, I'd gotten to a better focus just doing it manually so I think I'd benefit from some guidance from others on how focuser step size is determined for this combination of gear.
If any of you with CDK's could share your experience in setting up efficient step sizes, I'd much appreciate it. Its possible that the conditions tonight were the main problem, but still, it would be interesting to learn if there is a specific step size or a specific approach to determining it that some of you had found. Looks like it will be another week before a clear night rolls along to work on this again.
Thanks for giving this some thought...
Gary
ps: Next I’ll be working out autofocus in NINA so any insights on the Hedrick focuser step size in that context, would also be very welcome…
Edited by GaryShaw, 07 May 2024 - 10:53 PM.
