I have a Celestron Tripod for a C8, circa 1985. One of the plastic pieces at the leg joint is broken. It is marginally usable if the legs are fully extended, but the repaired leg is slightly wobbly. I added a hose clamp to keep the lower leg extended. Unfortunately, although I am tall, the telescope is too high in this position.
Fragments from the broken plastic are stuck at the interface, the lower leg doesn't slide freely as it should.
I am pretty good mechanically, but even if I could find a replacement part, I can't figure out how this section is assembled. There is a trick that I haven't figured out.
A friend had a similar issue with his newer tripod. He had the lower legs welded into a fixed height. My driveway is not level, so this is not a good option for me. Besides, the plastic piece makes my fix more difficult.
Any ideas?
I am about ready to give up and buy a new tripod. My next post will be about wedge hole patterns.
Thanks.
