Lets say you could get hold of a lens with a guaranteed 1/8th wave P-V profile, still an achromat. Would you replace the objective in a Shortube? Or is it a case of "pearls before swine?" In other words, does it "violate" the concept of the Shortube 80mm as a very inexpensive, low power sweeper? Should, if they were available, high-quality achromats be confined to more refined tubes with 2-speed focusers, collimatable cellls, machined components?
If you could buy a high-quality lens, would you put it in a Shortube?
#1
Posted 09 May 2024 - 11:44 PM
#2
Posted 10 May 2024 - 12:52 AM
I have an old one, known as Photon 127f/9 around year 2000.
It has some blue chromatism but lenses are well made, with a very good star test.
I tuned the air gap (2.5mm now versus 2mm when I got it) and did the lens retro-engineering. Spherical aberration PtV is at the level you said from 535 to 615nm.
As it can magnify a lot now (>x200 on Moon) I made a effort for fine focusing and will do for internal baffling
Edited by lylver, 10 May 2024 - 02:31 AM.
- stevew, Illinois, RichA and 3 others like this
#3
Posted 10 May 2024 - 04:01 AM
How much would it cost for what focal ratio and aperture?
- vtornado likes this
#4
Posted 10 May 2024 - 05:31 AM
The concept of a fast (say F5) "standard" achromat from 80mm to 150mm is all about low power, sweeping and deep sky observing. There is no need for anything more than diffraction-limited optics for that purpose. Most all aberrations have minimum impact when the magnification is low. The attractiveness of such scopes is their low price and bang for the buck delivery, if used for that particular purpose.
At one time I owned a University Optics 80mm F6.25 refractor. These are regarded as having a very nice and sharp Japanese lens (using FK5) and rightfully so. That scope was much sharper than the Orion 80mm F5 that I had but not a true ED lens. The tube was all metal.
However, under a dark sky, my 102mm F5 achromat (like the Sky Watcher Startravel) was easily the scope of choice for low power deep sky observing, even though the lens in that scope was not as well figured and was faster than the University Optics 80mm. For other uses, the UO 80mm was better. But today, an "excellent" 80mm ED would best the UO 80mm, even though the old UO was an excellent scope for the day.
HERE is one link to a thread here on CN about the UO 80mm
HERE is another link to a thread on CN about the UO 80mm
Below is my old UO 80mm.
Bob
- gnowellsct and therealdmt like this
#5
Posted 10 May 2024 - 06:21 AM
Are you going to pimp out the 60 ?
#6
Posted 10 May 2024 - 08:17 PM
An 80mm f5 achromat has significant limitations that cannot be overcome simply by replacing the objective with a higher "quality" lens that is still an 80mm f5 achromat. It is pretty easy to throw a lot of money at an inexpensive scope but generally it will not change the character of the scope in the end.
"Should, if they were available, high-quality achromats be confined to more refined tubes with 2-speed focusers, collimatable cellls, machined components?"
Are you implying that there are no high-quality achromats available today?
dan
- Brent Campbell and Terra Nova like this
#7
Posted 10 May 2024 - 08:20 PM
Sure. I'd put a triplet with two fpl-53 elements in my ST102.
- gnowellsct and 25585 like this
#8
Posted 10 May 2024 - 09:20 PM
Or maybe glue all three lenses in correct order to a yardstick, forget the tube, prop it up on a broomstick and you're good to go. --GN
#9
Posted 10 May 2024 - 10:39 PM
Not sure. I'd guess $400.00 or so.
#10
Posted 10 May 2024 - 10:41 PM
da
I don't know of any high quality achromats with fast focal ratios in amateur telescopes.
- 25585 likes this
#11
Posted 10 May 2024 - 10:45 PM
Poor surface quality, inaccurate curves, will only compound existing problems.
#12
Posted 11 May 2024 - 03:19 AM
$400 buys an 80mm f/7 ED with very nice mechanicals. Optically, it would outperform a 1/8 wave 80mm F/5 achromat because of the chromatic aberration.
I have a 80mm F/5 with a 2 inch focuser that has a decent lens. It offers a somewhat wider field than the AT-80LE which is an 80mm F/6 FPL-53 doublet but otherwise, the AT-80LE is a much better scope both optically and mechanically.
Posted 11 May 2024 - 03:43 AM
As a "Proof of Concept" exercise I have mated a William Optics 80mm "Semi-Apo" Megrez II lens cell to a cheap Chinese optical tube (80/500). The pics don't show it but I added a GSO 2-speed Crayford as well. Since the lens cell and body do not mate together natively, and it has turned out to be prohibitively expensive to manufacture a mating collar, I attached the cell to the tube using electrical tape. The resulting Frankenscope performs very well, indeed. I need to add more baffling, but so far I am impressed with the performance.
- RichA, therealdmt and topomountain like this
#14
Posted 11 May 2024 - 08:41 AM
i have two japan f5 achromats from vixen
80 f5 tasco 10vr
60 f5 tasco 9vr
these are nothing like the st80
they both have very sharp lenses, of course they are f5 but it is easy to tell the difference.... about once a year i see a vixen 80 f5 achro come up on CN and they sell fast
i would gladly pay for a 100 or 120 f5 for that kind of lense
#15
Posted 11 May 2024 - 08:46 AM
I actually don't think I'd buy another 60 to 80mm conventional telescope.
Maybe a spotting scope with ED glass.
#16
Posted 11 May 2024 - 10:47 AM
Except the ED will likely violate two positives of the Shortube: Lightweight and size. The idea isn't to be optically perfect, just better while preserving the attributes of the Shortube.
- Echolight likes this
#17
Posted 11 May 2024 - 11:28 AM
Thing is, the F/5 achro lenses could be P-V 1/10 wave and it still not be any better. The issue with an F/5 achromat is not the lens figure, the issue is it is an F/5 achromat. The Chromatic aberration swamps things like spherical aberration (SA) that are corrected with a well figured lens. Then in an 80mm F/5 you also have field curvature which would be more noticeable than the delta of 1/8 P-V performance over diffraction limited P-V 1/4 wave performance. Some people can cope with the field curvature or are only doing high mag, but there is still the CA issue.
So take care of the CA of an F/5 with SD glass (or go to F/10), then you can start addressing the SA and if you have P-V 1/8 wave performance.
- Jon Isaacs likes this
#18
Posted 11 May 2024 - 12:38 PM
What would be the point. An achromat is still an achromat and a short achromat is a short achromat with all that that implies. I built (CNC) a completely custom ST80 and put a defraction-limited Vixen lens in it. It still had the achromatic color blur that comes with such as the magnification was increased.
- Jon Isaacs and therealdmt like this
#19
Posted 11 May 2024 - 02:38 PM
So the triplet with 2 fpl-53 elements it is!
#20
Posted 11 May 2024 - 05:25 PM
I had a semi-apo WO scope that was far far sharper than a Shortube and that wasn't down to just colour. It was a 70mm f6.
#21
Posted 11 May 2024 - 06:05 PM
Yes, for a good optical finder. say a quality spotting scope lens which at 80mm are better than short achro refractors.
#22
Posted 12 May 2024 - 03:48 PM
Edited by betacygni, 12 May 2024 - 03:56 PM.
- RichA and 25585 like this
#23
Posted 13 May 2024 - 05:39 AM
Upgrading an ST-80 means a 2 inch focuser which adds to the weight. The lack of a sliding dew shield adds to the size. A clamshell or tube rings are necessary for proper mounting. With the better optics, one needs something better than the plastic cell that comes with most ST-80s.
This is my current ST-80 though it's one long term loan. It is unlike the vast majority of ST-80s in that it has a metal lens cells that threads on to the OTA and a metal dew shield that threads onto the lens cell. The optics are sufficient to easily split the double-double.
- dan_h and RichA like this
#24
Posted 13 May 2024 - 05:48 AM
The 80mm F/5 Skywatcher Esprit is the obvious choice. It's an FPL-53 triplet and only $2230...
Personally, upgrading the optics in an ST-80 doesn't make a lot of sense. If one is going to spend the money, an F/6 or F/7 ED/apo is the way to go.
Edited by Jon Isaacs, 13 May 2024 - 05:49 AM.
- dan_h and 25585 like this
#25
Posted 13 May 2024 - 07:47 AM
