Hello all.
I have recently acquired a Skywatcher Evostar 80 ED that I have been using a lot for learning the skies. It's a nice, small, easy to use scope that provides an expansive field of view that my larger scopes can't compete with. And it may be the only scope I own that I'd keep forever...unless some extraordinary deal for a little 85 or 90 apo came along.
So an appropriate eyepiece picked especially for it seems justified, especially since I acquired the new scope at a used price.
I have been using the WO 40mm SWAN which gives a nice wide bright image. Although it is not the most well corrected eyepiece, I appreciate that it is generally easy to look through.
My next up eyepiece is an APM 20mm Hyperwide which is great in my larger scopes. But it seems to be a giant step down in brightness in the little scope. And requires a noticeable amount of increased effort to use in the 80 f7.5, as opposed to the 40mm 70 degree eyepiece with it's larger exit pupil and generous eye relief.
Originally I thought that I'd be happy with the big jump between 40 and 20 since the 20 was a 100 degree eyepiece. But the difference in image brightness in the small scope leaves me looking to fill the middle ground. I often find myself wanting a little bit more magnification than the 15x that the 40mm provides, but a brighter picture than the 20 offers. And a lot of times think I'd like a step up in image quality over the 40 SWAN.
So I am interested in your preferences for wide field eyepieces for this or similar telescopes. I mainly view from about a bortle 7.5 back yard. I can generally see the main stars of the constellations, and the brightest DSO's like M45 naked eye.
My budget will be in the $200 to $400 retail range, as I'd like for this to be a lifetime eyepiece that could be used in the ED80 as well as whatever other scopes I might have now or in the future. But nothing too extravagant.
Comfort, ease of viewing, non-critical eye position, decent exit pupil over the 20mm, 2 inch barrel, 800 gram max weight, and a sharp image across the field is what I would like. And probably something at least a smidge north of 15mm eye relief. Camera threads for eyepiece projection photography might also be nice.
I appreciate any direction and guidance you could offer. Wether it's an upgrade at or near 40mm or an eyepiece you love between 24 and 35mm.
Edited by Echolight, 11 October 2020 - 11:58 AM.
