Samsung SCC-A2333 Remote Control Project
#1
Posted 15 October 2010 - 07:14 AM
You don't have to use the same connectors as I do, or even mount your connectors in the same place, it's just how I did it. Feel free to copy the idea or come up with your own.
The important thing is the correct wiring!
Thanks to Martin Lyons for sorting out the wiring for me
OK here is the Project.
Pic 1 shows all the parts you will need (if you do it the same).
The reason I use a small box for the camera connector is so the cable connector didn't end up pointing out sideways creating its own problems. This way the cables can all flow together.
I am using 30 feet (10m) of Data Cable.
#2
Posted 15 October 2010 - 07:20 AM
'D' connectors are small, neat, and can by locked with the 2 thumbscrews so the cable won't fall out.
I mounted the Camera connector into this small Project box so the 'D' connector would be facing towards the back, enabling all the camera cables to run together.
The other connector simply goes into a 'D' connector housing called a 'Shell'.
#4
Posted 15 October 2010 - 07:30 AM
Remove the small connector box from the case and remove the case from the camera.
The terminals in the camera are very easy to get to, and easy to solder but BEWARE of getting the contacts too hot. You don't want to damage the switch in the camera.
Also connect the wires to the 'D' connector.
There is no specific order for the 'D' terminals, just make sure the colours match up on the other half of the 'D' connector (the cable end).
At this point you will need a 7th wire. This wire goes from the shielding in the Data Cable to the chassis of the camera. I just used a scrap piece of wire.
#7
Posted 15 October 2010 - 07:40 AM
Neatness isn't essential here as you can tell by looking at mine
Just remeber that 'ENTER' is the centre switch, the others are self-explanatory (left, right, up, down).
It is also worth fitting a Cable clamp to the Data cable at this point. This will stop the cable from spinning inside the box, which can twist the wires inside and pull them off the switch terminals.
It also prevents the cable from accidentally being pulled out of the box.
#9
Posted 15 October 2010 - 08:49 AM
#10
Posted 15 October 2010 - 08:51 AM
Very nice work. Clean, simple, with good suggestions.
I also really like the idea of the inexpensive "parasitic" box to mount the connector without any strain relief problems.
#11
Posted 15 October 2010 - 09:27 AM
The hand controller is bigger than the camera though
Nice work
#12
Posted 15 October 2010 - 04:33 PM
Nice Work Ken_Martin_Bruce,
Rick
#13
Posted 15 October 2010 - 04:58 PM
#14
Posted 15 October 2010 - 05:34 PM
http://www.surveilla...om/scc-101.html
#15
Posted 15 October 2010 - 06:35 PM
Rick
#16
Posted 15 October 2010 - 06:44 PM
doesn't the 2333 have rs485 on the terminal block, and not just the control over coax -- and can use one of these ?
1. Yes, you can use one of those, but the wiring job is messy and it looks amatuerish. Those little devices don't have just one cable. And it's a DIY wiring job. Strange for a commercial product.
2. That actual controller isn't made for these models (SDC-435, SCC-A2333, etc) but apparently can be made to work.
3. Availability is very limited.
4. I like mine better coz I did it myself
#17
Posted 15 October 2010 - 06:51 PM
A very good idee
Nice work
Yep.
Doesn't matter in my case as I won't be holding it in my hand. Mine sits on the desk with my electric focuser control etc. I just push the buttons.
And the electronics shop didn't have a great range of sizes either
#18
Posted 16 October 2010 - 01:04 AM
#19
Posted 16 October 2010 - 05:27 AM
I like yours too!
thanks Bob
The whole lot: boxes, switches, 30' cable, etc. cost me $30
#20
Posted 16 October 2010 - 05:23 PM
Was playing with my GStar yesterday - I need one of these as well. I'll add it to my list of future jobs.
#21
Posted 16 October 2010 - 11:05 PM
Looking good Ken.
Let me at it with my trusty Soldering Iron, Eric
#22
Posted 17 October 2010 - 04:13 AM
Looking good Ken.
I got inspired and pulled the cover off! After inspection I put it quietly back on - very compact setup - looks like double-sided circuit boards. No ready access to the pushbutton switch terminals. That's OK - stops me breaking it!
#23
Posted 24 February 2011 - 01:20 AM
