Which Travel Scope for Hawaii?
#26
Posted 13 October 2011 - 09:09 PM
Unfortunately, from Cpt Cook I really can't give you a clue of where to go. That part of the island is more heavily populated which can make it a challenge. I would try watching for a good spot while your out sight seeing. South point would be great, if the wind dies down, but you cannot count on that there. The good news though is you will be close to some great dive areas. Check out darkerview.com for some great reading and great photo's.
#27
Posted 13 October 2011 - 09:22 PM
#28
Posted 14 October 2011 - 08:29 AM
You may not find blackest skies on the south, but it shouldn't be hard to find something good with a little research. I would think heading toward Volcanoes and then turning up the mountain would get you somewhere good. There are some trailheads up the mountain (I don't remember exact road names) from Volcanoes and even before you get there. Ultimately, I think you can drive a long way toward the Mauna Loa summit from the south (though not nearly all the way, but enough to get you up a few thousand feet).
We stayed in Ocean View last trip and there were lots of really good skies nearby. Again, not black, but very dark.
#29
Posted 14 October 2011 - 10:20 AM
If you head south, and if you know what you are doing with scuba gear, check out Kalae Cape--when the sea is calm. Lots of big octopus.
Dark skies.
Jack Turner
#30
Posted 17 October 2011 - 02:01 PM
I have a condo in Kona and often have my items shipped to their office a week in advance.
#31
Posted 17 October 2011 - 11:25 PM
The 6SE in dark skies will let you go deep when you get settled down from using the binocs. And with all those stars you'll see, you might find the goto helpful.
Patrick
#32
Posted 18 October 2011 - 01:12 AM
Make that 2 votes for this very nice refractor. Heavy emphasis on widefield viewing is definately what I would be after.
So far, the recommendations seem to favor the 6se.
David:
If it were me, I would take the 90mm refractor. It is simpler to use, there is essentially nothing that can fail and it offers a widefield of view that is particularly well suited for discovering skies I have never seen before.
Posted 18 October 2011 - 06:11 AM
Nothing better for wide field viewing than a pair of binoculars, IMHO. Especially nice when mounted on a decent tripod. One eyed viewing at 3° versus 6° with two eyes...no comparison. The 90mm refractor would be nice too though, no doubt.
Patrick
#34
Posted 18 October 2011 - 11:21 AM
One eyed viewing at 4° and still have the capability of splitting double stars and partial resolution of globular clusters,both unseen by myself. You bet this 90mm scope would be nice to take along as my one and only piece of astro gear.Heavy emphasis on widefield viewing is definately what I would be after.
Patrick
#35
Posted 18 October 2011 - 11:26 AM
Patrick
Optically, binocs indeed represent a wonderful wide field, low magnification solution. Optically.
However, from the standpoint of ergonomics, binoculars leave a lot to be desired. Unless we're talking about binoculars designed specifically for astronomy (that is with right angle eyepieces) binocs on a tripod are, IMO, just about useless for astro viewing. You'll need a neck and back far more limber than most of us have to view comfortably at any angle much greater than about 30 degrees.
Hand held, binocs fare better but still you have to contend with the stiff neck problem and discomfort when observing at close to zenith. A parallelogram mount (bulky, clumsy and expensive) helps a bit but you're still stuck with craning your head back to view at zenith.
For me, the only way conventional binocs work at all well for extended viewing is to lay back on a chaise lounge and use them. Still somewhat uncomortable but better than any standing alternatives.
#36
Posted 18 October 2011 - 01:35 PM
Patrick
#37
Posted 18 October 2011 - 03:15 PM
I certainly agree that binoculars are a must-have for a Hawaiian vacation.
#38
Posted 18 October 2011 - 04:24 PM
Definitely make it a point to check out Omega Centauri. Through a telescope, it's beautiful even from where I live (Phoenix), where it's low on the southern horizon.
#39
Posted 18 October 2011 - 04:35 PM
If it works for you that's great. But for me, using conventional binocs at or near zenith is impossible with ANY tripod - be it superb, decent or indecent. You can crank a gear column all you want but you still can't get anywhere close to a comfortable viewing position with the binoculars pointed straight up.
Straight up? ...no, me either. I'm good up to about 70 deg max, but not for extended periods. But I wouldn't be looking straight up in Hawaii. I'd probably be focused on looking southward. Then when I got tired looking through the binocs, I'd pull out the C6 and go deep, and then go back and forth between them. That'd be kind of nice! Nice to think about on this overcast day here in Ohio.
Patrick
#40
Posted 19 October 2011 - 11:10 AM
Straight up may still be an issue, but I know I could look a fair ways up without discomfort.
Two more things going for the monopod - low cost and portability.
#41
Posted 19 October 2011 - 12:58 PM
By the way, you do not need a jeep to make it up to the visitors center. Apparently saddle rd is not as bad as it once was. I made it up there in a mustang convertible (I think i rented from alamo) and don't remember it being so bad (NOTHING compared to piilani hwy on maui).
