#1
Posted 15 December 2014 - 01:03 AM
#2
Posted 15 December 2014 - 01:52 PM
http://www.bhphotovi...mputerized.html
I tested the optics on one and it had a very good figure.
straight lines are good, curved are bad....
also the hand controller may come set to Russian so here's the fix
http://www.cloudynig...9995/?p=6347472
Edited by Pinbout, 15 December 2014 - 02:23 PM.
#3
Posted 17 December 2014 - 01:00 AM
WisdomLikeSilence, welcome to CN and congratulations on your degree. No recommendations for you but best wishes on your journey into this hobby!
John
#4
Posted 17 December 2014 - 02:31 AM
For a beginner, I would go the direction, you said you didn't think you want to. You have a truck, so transporting a Dob would pose no problems. Collimating is a pretty simple task. You will get more aperature for your dollars. The dob is a lot more forgiving , if you don't have really dark skies. Just a thought. Orion makes an Intelliscope line, which is a push to, but has no tracking. By push to I means there is computer assistance, letting you know where objects are. Then you just push to the coordinates on the view screen. 6" Intelliscope is very portable and in your price range. Just thought you might want to take a look.
Good luck on whichever direction you decide. There is a wonderful sky out there just waiting to wow you.
#5
Posted 17 December 2014 - 08:08 PM
Welcome to cn, I wouldn't rule out an sct on a goto, or mak. They would give you a bit more aperture when I started back into this hobby with goto it had a 90 mm refractor and my only complaint was a lot of the stuff in the goto library was really not that appealing in a 90mm. Sct and maks really hold colimation well, in 6 years have never touched my mak, and maybe once on my scts. Just something to think about. Really what ever you choose you will enjoy, have fun, don't stress over your choice that much.
#6
Posted 18 December 2014 - 12:11 AM
William Optics makes wonderful refractor telescopes. Although the Z71 is a small aperature instrument, it is a great place to start. Build quality and function, especially the dual speed focuser, is exemplary. For its size, it is built like a tank. Optical quality (the Z71 is a doublet) is excellent with some chromatic aberration to be seen for sure, but it does not take away from the views you would expect to see with a telescope of this size or optical configuration. I have used mine for solar work and double star observing and find it to be easy to use, mount, and move which translates into using it often. The Z71 does not come with a case (one is available through William Optics or affiliated dealers, and you will have to save your original styrofoam packing) if that matters, but it is an additional expense to bear in mind. It is a marvelous little telescope and as I stated before, a great place to start observing the heavens.
Bill
