Captures and observations from SX Ultrastar mono first light last night.
Setup: C8@f4 using Meade 3.3FR (Japan), SX Ultrastar Mono (Sony 825 sensor), AVX EQ Mount, Orion SkyGlow Astrophotography Filter and Starlight Live software v1.1
Conditions: Heavily Light Polluted Location (visually only mag 3.5 and brighter stars visible), seeing and transparency both were average but struggled with high humidity later in the evening as the battery powering the dew strip died (forgot to charge it).
Initial observations:
- As expected the 825 sensor at a high FR works best for larger DSOs. Overall really enjoyed the larger FOV on nebulae and supernovae remnants but missed the perfect image scale X2 provides for smaller galaxies
- In my view the 825 at x1 bin mode is at least 1.5 - 2 stops slower than the X2 but still is an acceptable compromise between my ‘need for speed’ and ‘need for resolution’
- Starlight Live (lodestar live) SW does not yet have a bin option so could not try it out but I think at x2 bin 825 should provide similar speed as the X2.
- The sensor is very ‘clean’ – very few hot pixels. Very viable for traditional style imaging as well after using darks
- I was surprised by how well the Meade 3.3 performed. There was some vignetting at the corners of the frame and some coma but overall the image was very good (at least for EAA)
- Stacking with Starlight Live SW was much slower and it really struggled to stack frames for objects in rich star fields. It refused to stack 11/15 perfectly good frames with pin point stars for the Wizard Nebula. I don’t this this is a big issue to fix – just need to optimize the registration process a little bit when there are too many stars.
You can find the images here: http://stargazerslou...no-first-light/
