If you have a spare 8x50 straight-through finder scope, you can easily convert it to a 200mm f/4 telescope to use with an image intensifier such as a PVS-7 or NVD Micro. With these scopes, this setup will produce approximately 7x magnification and a 5.5 degree field. If you've done astronomy for a while, you probably have a few of these finders sitting unused in a drawer somewhere.
As these are cheap achromats, there is tons of CA. The unfiltered view will show very bloated stars. But, as soon as you install a filter, the view improves dramatically.
These scopes are great for hand-holding and sweeping the Milky Way. With an H alpha filter, there is enough magnification for very good views of the North American / Pelican, Lagoon, Swan, etc. This little scope is also great for sweeping up and down the star clouds, dust lanes, and dark nebula of the Milky Way.
All you need to do is to follow Michael Fulbright's instructions for modding the finder to accept 1.25" eyepieces. These instructions are available here: http://msfastro.net/...cope/index.html
Just replace the guide camera with the intensifier's 1.25" nosepiece and you are good to go.
The image-intensified finderscope is a good alternative to camera lenses for low-power observing.
