Rebar in pier and pier footing
#1
Posted 19 January 2014 - 08:18 PM
1. Do I assume 1 layer of rebar is sufficient.
2. How do you bend the rebar or can i just use the wire mesh home depot sells?
thanks
Posted 19 January 2014 - 08:30 PM
I think one layer will be fine. You may want to isolate the concrete from your floor using foam around the sides. Then you can dissolve it after. This way, footsteps are completely isolated.
#3
Posted 19 January 2014 - 08:46 PM
I have another question if you know. My observatory is 3' off the ground. What is the best flooring material to use?
I was going to use OSB but I realized that it is not rated for outdoors.
#4
Posted 19 January 2014 - 09:56 PM
Regular construction-grade plywood will hold up quite a while if 3' up, but you can also get pressure-treated ply, and there is a next-level OSB called advan-tek which is made with waterproof resins and is rated exterior. PT ply can be found at big-boxes, the advantek will likely have to come from a lumberyard.
R
#5
Posted 19 January 2014 - 11:35 PM
#6
Posted 20 January 2014 - 12:11 AM
#7
Posted 20 January 2014 - 08:05 PM
#8
Posted 20 January 2014 - 08:07 PM
#10
Posted 21 January 2014 - 06:15 AM
Norm
#11
Posted 21 January 2014 - 07:26 PM
#12
Posted 22 January 2014 - 12:31 AM
#13
Posted 22 January 2014 - 12:48 AM
Your 1-2 days of freezing is nothing to worry about.. The ground doesn't freeze. i'd be more worried about our ground shifting (all the ground near the coast is pretty much sand.. they built the houses on sand dunes and wetlands..) and earthquakes.. Not going to do much about earthquakes but 1.5 tons of concrete in a pyramid shape in the ground sure does prevent any shifting.. a 3.6 quake (small of course) and my pier footer laughed out loud.. lol!
#14
Posted 22 January 2014 - 02:58 PM
An acetylene torch can also be used to bend and cut rebar. Heating it up to a nice red makes it easy to bend - even right angles. A cutting torch can be used to cut it.
Heating rebar is not a good practice.
#15
Posted 22 January 2014 - 03:18 PM
Yea, probably better to use a grinder (with a metal-cutting blade) or a skilsaw (with a metal-cutting blade). Only takes a few seconds, and is quite safe, with reasonable precautions.
#16
Posted 22 January 2014 - 03:49 PM
#17
Posted 24 January 2014 - 02:23 PM
And the reason for not heating rebar is..... the coating contains zinc, either zinc chromate (Lime green color), or galvanized (battleship grey). Very bad for your lungs when inhaled.
Clear Dark Skies
Startraffic
39.138274 -77.168898
#18
Posted 24 January 2014 - 10:52 PM
#19
Posted 28 January 2014 - 03:06 PM
I poured a 12 inch diameter pier, 4 feet above ground and 4 feet below ground (frost line), 10 years ago with no rebar and it's going fine.
My wife is a construction manager (custom homes) and she doesn't put rebar into foundations. I asked her this very same question, and she told me I didn't need it.
#20
Posted 28 January 2014 - 11:08 PM
-Dan
#21
Posted 29 January 2014 - 10:29 AM
A little extra insurance at a small expense.
#22
Posted 29 January 2014 - 11:33 AM
Thanks. I'd heard that rebar saves you from "bad pours".
I would question the real need due to lateral loads and frost, since rebar is not required, nor used in foundations our houses, here in the northeast. If there were ever a problem with lateral loads, and frost, it would be in the foundation of a house, and less so in a pier.
I'm not trying to be argumentative (and I'm sure this will bring nasty comments), but it seems to me that people put in rebar simply because "its always done in large buildings". Indeed, I asked one of my fellow club members why he put rebar into his pier and he said "it makes it stronger".
I'm just trying to determine if using rebar is a myth, or a real engineering requirement.
#23
Posted 29 January 2014 - 12:15 PM
#24
Posted 29 January 2014 - 02:57 PM
I'm not sure where you're getting that information. I'd check with your local building inspector.
I'm also in the Northeast, near Rochester NY, and rebar is required in foundation pours here. You're absolutely correct that side loads in a basement are much larger than in a pier. In our climate, you simply could not pay me enough to build a house on top of poured concrete basement walls that have no rebar.
In fact, you can look up your (Massachusetts) building codes online. Your state has links to the ICC code site because that's what they use. Check out this page for foundation wall specs:
http://publicecodes....12_4_sec004.htm
Scroll down to the section for concrete foundation walls and you'll see the required spacing and size for reinforcing bar.
As Tim points out, it's cheap and easy to add rebar to your pier. Do you really want to take the chance of having to dig up a cracked pier after an observatory has been built around it?
-Dan
#25
Posted 01 February 2014 - 11:03 AM
How long should I wait to pour the footer?? Just wiat until it feels dried out? I'm thinking that it just needs to be dry to the touch.
