4x4 wooden pier
#1
Posted 09 April 2014 - 01:23 PM
Apart from the usual "why are you not sinking a 12" concrete pier? No such thing as over engineering" comments can anyone make an educated guess as to what the maximum loading would be? I dont really mind a good few seconds dampening but I dont want the thing moving in the ground. I'm not really planning on using concrete just backfilling and good tamping down with a sledge hammer. The post is 2.4m and i'm going to sink about half in the ground so i'm hopeful it wont be too unstable.
#2
Posted 09 April 2014 - 01:34 PM
#3
Posted 09 April 2014 - 01:39 PM
#4
Posted 09 April 2014 - 01:43 PM
#5
Posted 09 April 2014 - 01:56 PM
#6
Posted 09 April 2014 - 02:20 PM
#7
Posted 09 April 2014 - 02:22 PM
I'm assuming it'll be perhaps 5' tall - like an 8' piece buried 3' or so..... sounds a lot like a lot of fenceposts here on my farm.... if you rap it, it'll vibrate for a few seconds, but if not, it'll be plenty stable enough for visual work. Some lumberyards also sell 4x6 timbers, you could check the price of them. Depending on your soil composition, you could also backfill it with packed sand, which would absorb vibration better than very heavy soils.
Russ
#8
#9
Posted 09 April 2014 - 02:49 PM
I have seen "sleepers" that are 6x4 but they are only 1.2m locally. If I can find a 2.4m sleeper for cheap I will go for that as it sounds like it will be fine.
#10
Posted 09 April 2014 - 02:51 PM
I had expected to have to dig it out when the time comes but I don't fancy breaking up concrete! I hadn't considered just sawing it off and leaving the footing, that might be an option.
#11
Posted 10 April 2014 - 08:39 AM
I'd say a 4x4 isn't nearly big enough and is going to flex.
Chris
#12
Posted 10 April 2014 - 09:09 AM
Thanks for your input, it's always good to get opinions of people with hands on experience of these things.
Gordon
#13
Posted 10 April 2014 - 09:20 AM
I've got a 6x6 post in my shed. It's better than a tripod, but it still is pretty touchy if you're doing visual. Someone built a 4 x of 6x6 posts and bolted them together and I think that would give you the mass you need to keep it stable. Not nearly as cheap, but what's 150 bucks in lumber?
Don't forget the price of the bolts. Those big ones aren't cheap.
#14
Posted 10 April 2014 - 09:47 AM
http://www.gardiners...Sleepers/New...
Should be just the ticket
#15
Posted 10 April 2014 - 06:49 PM
#16
Posted 11 April 2014 - 07:14 AM
#17
Posted 11 April 2014 - 09:45 AM
#18
Posted 11 April 2014 - 12:44 PM
#19
Posted 11 April 2014 - 12:50 PM
#20
Posted 11 April 2014 - 01:04 PM
I was also thinking of screwing bits of 2x4 horizontally across it to give it better anchorage in the backfill.
#21
Posted 11 April 2014 - 01:33 PM
#22
Posted 11 April 2014 - 01:44 PM
#23
Posted 11 April 2014 - 02:25 PM
#24
Posted 11 April 2014 - 03:42 PM
#25
Posted 12 April 2014 - 07:54 AM
http://sawyerventure...-offer-expired/
At first when I posted I thought there was no way it was going to work.. but I kept at it, and after about 45 of poking that thing around it I pulled it out of the ground.
I'm pouring concrete today .
