Bob's Knobs
#1
Posted 11 February 2010 - 12:42 AM
My 6se is still in collimation, but I'm sure it's only matter of time. Since I've never tackled it or even seen it done I figure when it's time, I will curl up in a ball and wet my pants. But for now I think I'll just find someone who knows what they're doing and ask for help.
I am however, even now considering Bob's Knobs as an alternative to the factory screws. Can anyone tell me if this is a good idea?
#2
Posted 11 February 2010 - 12:51 AM
#3
Posted 11 February 2010 - 04:06 AM
Bob's Knobs are indeed a great convenience which allow one hand to reach around the front of the OTA to make adjustments while viewing and their use also has the added bonus of removing the potential hazard of wielding a screw driver or Allen key (wrench) in the vicinity of the corrector plate.
Buy them then with all blessings, but the general concensus of opinion is not actually to fit them until you really feel your 'scope is in need of colllimation and from what you describe in your other post, it is currently performing well.
The collimation process itself is straightforward enough. Just ensure a good, still seeing night on which to carry it out, and, if for any reason you do feel slightly out of your depth on this one, just shout ! We're all here to help one another !
Best regards,
Tel
#4
Posted 11 February 2010 - 04:16 AM
The secondary mirror does not bounce well; especially off of the primary ! :rofl2:
Best regards,
Tel
#5
Posted 11 February 2010 - 04:21 AM
I will likely need the help.
#6
Posted 11 February 2010 - 08:06 AM
Sounds like a lot of extra work but it is not...pretty easy to come back real close to being perfectly collimated between installing the next knob...
You really are not ever all that much "off"
Bob G
#7
Posted 11 February 2010 - 08:08 AM
If you scope is like most peoples, Bob's Knobs will rust away before you need them.
#8
Posted 11 February 2010 - 09:10 AM
It's also possible to replace only two screws and get an X-Y adjustment scheme thereafter. If anyone is interested I can describe the procedure.
#9
Posted 11 February 2010 - 10:33 AM
Welcome to CN and the NexStar forum in particular.
Don't forget that for collimation (or re-collimation):
1) you need a night with VERY GOOD SEEING, not just good but very good/excellent
2) re-centre the star EVERY TIME YOU MAKE AN ADJUSTMENT OF THE COLLIMATION SCREWS
and
3) PICK A BRIGHT STAR for collimation at a reasonably high altitude - eg Vega
Art
#10
Posted 11 February 2010 - 11:15 AM
Hi Bill,
Art
Vega
Why Vega in february??
sometimes i prefer not to select a star too high so it is easier to reach my Bob knobs with the dew shield on.
If you travel with your scope, Bob knobs are essential. If not, collimation will not need to be adjusted that often.
#11
Posted 11 February 2010 - 11:19 AM
It's getting nice & high by dawn.... but in the evening Capella is probably better. Or Polaris if you're at a highish latitude.Why Vega in february??
#12
Posted 11 February 2010 - 11:52 AM
I just plucked Vega out of the air (so to speak) as an example of a bright star that one would use for collimation purposes.
Capella is a much better bet at the moment (and will be until early summer).
Isn't Polaris a tad dim for collimation purposes?
ARt
#13
Posted 11 February 2010 - 11:56 AM
I find it perfectly adequate .... and it's convenient as it doesn't need "chasing" across the sky, even at high power.Isn't Polaris a tad dim for collimation purposes?
#14
Posted 11 February 2010 - 02:50 PM
#15
Posted 11 February 2010 - 03:13 PM
Peter.
#16
Posted 12 February 2010 - 05:21 PM
Eddie, I would like to hear this X-Y adjustment scheme.
#17
Posted 12 February 2010 - 06:29 PM
The advantage is that screw A will never come out or hit bottom because it's never touched and using the scheme above will give you the X/Y motion most people expect. The Y axis does not have to be vertical. The X axis will still be at right-angles to Y which is the orientation we need. Try this with a paper plate marked with the three screws.
