Image slightly shifts while rotating focus
#1
Posted 12 September 2010 - 11:31 PM
The fourth night (tonight) posed a new problem (at least for me). I noticed for the very first time, that when I rock the focus back and forth that the image is shifting. It actually seemed to have started about 15 min into my observing. When I got to M13 is when I noticed it. As the night went on about 2 hours later, then it became less or intermittent. When I started the Double viewing, it seems not as bad or barely noticable. Loosening the Mirror lock knobs about 7 turns out seemed to have made "some" better, but not like the first 3 nights out. The image was rock steady in the middle while I adjusted focus in and out. Nothing in the EP moved while I was doing this. Now, tonight !
The focuser is what seemed to be at the root of it. I could take my finger and apply a very slight pressure either toward the scope back or side to side and I could see the image moving in the FOV.
This all started when I could not get my Diagonal to move so that I could adjust the position of the EP. As a matter of fact, I had a small panic in the fact that I noticed that while I was turning the threaded assembly (sorry can't remember the name) , that I was also turning the huge ring that is right up against the OTA. Somehow my smaller ring was stuck and I had to go ahead and remove the larger ring and take the assemblies into the house quickly to remove the EP. I really do not like the smaller ring for the diagonal, it is very sticky and it does not take much to get it stuck. So, it was at this point, I guess is when I started to notice things were not going well with the focusing. I do not see how in the world removing both visual backs (larger and smaller rings) would cause a focus problem. I think it was a matter of coincidence.
It could be that some of the "newness" of the mechanical parts is loosening up and might be causing this. I see that there are some screws that hold a plate onto the back OTA which holds the focuser assembly on. Could it be that these screws have become lose which is causing the focus knob to be very sensitive to the touch. It just seems now that just touching the focuser knob causes the images to shift.
I appreciate all the feedback from those that might have suffered this and I hope that it is nothing to worry about.
Donnie
#2
Posted 13 September 2010 - 08:19 AM
That is called "mirror shift" and it's a normal thing for an SCT, or any other scope that moves the primary mirror for focus. The primary slides back and forth on the baffle tube and there is always a bit of tolerance in there to allow for that movement. The focus rod pushes directly on the mirror cell of your C925, but as you can see it's slightly off center. So the pushing and pulling of the focus rod will also rock the primary mirror ever so slightly as you change direction.
I'm sure you will learn the trick to handling it soon enough, but the simple rule is to turn the focus knob very slowly the closer you get to focus. If you do that, you are less likely to pass the focus point and have to come back.
Ron
#3
Posted 13 September 2010 - 08:25 AM
You have an Edge SCT. Double check the mirror locks to make sure they are not dragging. They will make it worse if they are.
Ron
#4
Posted 13 September 2010 - 10:03 AM
Would going from a 74° house to about 90° make a diff? If I had to total the amount of time from OTA inside to outside when I started to notice this would have been about an hour. The other observation time, I had the OTA outside for about 1 1/2 hours before I even touched the OTA - focuser.
Maybe the grease or whatever had a thicker vicosity since it had been inside with much cooler temps.
Donnie
#5
Posted 13 September 2010 - 10:17 AM
David
#6
Posted 13 September 2010 - 10:36 AM
Yes, I will try that.
My other question that I would like to post is:
Does the mirror lock knobs have a "stop" to them or they just reach a point of turning and turning and nothing happens (applies to loosening)
Also the same with Focus knob. Does it have a "stop" to it.
thanks to all.
Donnie
#7
Posted 13 September 2010 - 11:31 AM
The very first time I ever did any imaging, I ran into mirror shift with a camera on my telescope. I got a super image of Saturn as shown on my computer screen, but it needed a hair of focal adjustment. As soon as I touched the telescope focus knob to adjust, Saturn disappeared and all I could see was black sky. This happened a few times before I realized what was happening. A JMI focusser solved the problem and I still use it today even for casual viewing.
#8
Posted 13 September 2010 - 01:46 PM
thanks to all.
Donnie
The mirror locks on the Celestron are progressive, so there will be a point they become very hard to turn when you lock the mirror. Loosening - they just become easier. It's a bit harder to tell unless the focuser is stiff.
The focuser does have stops on both ends.
Ron
#9
Posted 13 September 2010 - 02:09 PM
I learned about image shift when I started AP with my CPC 1100. Imagine, you set up an item that you are going to shoot a picture of, and then you realize the focus needs a bit of tweaking and then when you move the focus knob the whole image shifts position. That's how I learned.
The solution for me was an upgade to a focuser that adds on to the rear of the OTA. I went with the FeatherTouch ( .8" short travel because of clearance issues with my fork-mounted scope). Additionally this focuser has two focus knob speeds, regular and 10 to 1, and you can lock it down once it's focused. I'd recommend something similar if you plan to do any AP with the scope.
Enjoy your Edge!
Hope this helps,
CTSS
#10
Posted 13 September 2010 - 02:24 PM
Donnie
#11
Posted 13 September 2010 - 02:42 PM
I was thinking about starizona has that focuser that installs in place of the existing.
Donnie
That would be the Feathertouch Micro focuser. I have installed these on all of my SCTs and they help minimize the shift a lot. But they cannot eliminate it; only an external focuser can do that. The external focuser adds weight, so that's another issue to consider.
Ron
#12
Posted 13 September 2010 - 02:47 PM
What you do is just add that focuser on. I have found that the range of my FeatherTouch is not as great as the stock Celestron focuser, but, that was never a problem. I just use the stock focuser to get focusing close, and then I use the FT for fine-tuning.
You can see how I added the focuser in the picture below.
I'm really happy with the way the FT focuser eliminates image shift when I'm trying to find that perfect focus (usually with the help of a Bahtinov Mask).
Hope this helps,
CTSS
#13
Posted 13 September 2010 - 03:29 PM
Second drawback is it adds more weight to the already rear heavy scope.
I have Feather Touch microfocuser which replaces stock focuser and I see a tiny image shift when digitally zoomed at maximum with Nebulosity software and SXVR-M25C camera. I do not have much issue with mirror shift with my CPC0800.
Peter
#14
Posted 13 September 2010 - 04:44 PM
#15
Posted 13 September 2010 - 06:09 PM
Donnie
#16
Posted 13 September 2010 - 06:19 PM
Critical focusing is best accomplished when the focusing knob is turned in such a manner that the mirror moves against the pull of gravity. In doing so, any mirror shift is minimized. For astronomical observing, both visually and photographically, this is done by turning the focus knob counterclockwise.
So, at least in the manual image shifting is acknowledged.
Fair enough !
Donnie
#17
Posted 13 September 2010 - 08:59 PM
#18
Posted 14 September 2010 - 10:35 AM
#19
Posted 14 September 2010 - 10:55 AM
Any suggestions on how you corrected your same problem. When the threads stick it takes alot of efforts to right the problem.
Well, I am thinking that an aftermarket diagonal would have to do the job. Yes, I have found that there is hardly no play adjustment on the smaller visual back ring. Just a tiny tightening and then it is stuck and can not get it loose. I am thinking that the thread pattern is too course. They should have made the thread pattern (pitch) finer. For finer adjustment. Or have some type of thumbscrews. Does any one know of a Diagonal that would replace the stock one.
Donnie
#20
Posted 14 September 2010 - 10:58 AM
