Reverse T Adapter for EOS Lens
#1
Posted 15 January 2011 - 09:24 PM
I've been looking everywhere for an adapter to connect an EOS lens to a camera with T-threads on the body and have not been able to find one. Anyone knows where I can buy one of these? I know they exist.
#2
Posted 15 January 2011 - 09:48 PM
You can make one but not likely to reach focus at infinity. That is why there is an adapter for FD to EOS with optics inline, but they are not great.
Here is a link where this is discussed.
http://photography-o...ad.php?t=980571
Here is a better link that gets into it from the otherside. What I mean is that in the camera world the Pentex screw mount has a flange to focal plane of 45mm and Canon EOS is 44mm. Therefore to the manufacturing world it is not a possible combination thus not made.
http://www.bobatkins..._focus_EOS.html
#3
This assumes you are looking to use an EOS lens on an astro-CCD. If you are hoping to use an EOS lens on an old T-thread mount film SLR camera then I do not believe you would be able to focus to infinity.
#4
Posted 15 January 2011 - 10:03 PM
#5
Posted 15 January 2011 - 10:14 PM
The focus distance for EOS (EF or EF/S) lenses is *shorter* then the focus distance for standard "T-thread" or "T2" mount lenses. So a film SLR camera body designed to to accept T mount lenses would require the EOS lens to be mounted *INSIDE* the body of the camera - obviously impossible.
However in the astronomy world while we use T-thread all the time we do not maintain strict focus-distance measures. Most astro-CCD cameras will have the T-thread placed very close to the sensor rather then at the "T2 mount" official distance from the sensor - as a result there *IS* room for adaptors (like the ones I linked above).
Hopefully those linked adaptors are truly using T-thread, and that the camera you have will have a small enough distance from the thread to sensor to allow the lens to come to focus at infinity.
#6
Posted 15 January 2011 - 10:55 PM
I've posted a wanted ad on AMart to see if I can find one cheap. If not I'm just gonna buy an EOS body ring and spacers. My chip to flange distance is about 15mm. As far as I know EOS flange spacing is 44mm. So I'm hoping I can make one with the spacers and the ring. Will post the results if I succeed
#7
Posted 15 January 2011 - 11:10 PM
This mates any EF-mount (EOS) lens to an SBIG camera, with the correct spacing, i.e. when the lens reads infinity you are very close to infinity focus. Unfortunately I am not aware of anyone selling them. The brass ring is custom-made. I sent this specific image to SBIG in 2005(!), trying to convince them to have them available for sale. Perhaps they now sell them? Check their website. Issues you should be aware of:
1. It is exceedingly difficult to custom-fabricate the Canon EF bayonet, hence you start off by purchasing cheap EF extension tubes and dismantle the front from the rear, usually by simply removing 3 or 4 watch-screws.
2. You then get any metal-worker with a small lathe to make the much-simpler brass tube that has a male T-thread on one end and a flat side the other end. The 3 or 4 watch-screws are then used to hold the brass tube to the EF female bayonet. One can also use aluminium instead of brass, whatever scrap metal rod is available. The lathe work is well within a hobbyist's ability, the most skill (not very challenging) being required to make the T-thread, straightforward if your lathe has a facility for machining threads.
3. EF lenses need to be stopped down on an EOS camera with the shutter set to B, then removed from the camera body with the shutter still open. The aperture will remain stopped down, say, to f4.0 or whatever you desire. You then attach it to the CCD camera+custom adapter. Sounds more complicated than the reality, which takes a few seconds. I believe this may be the reason why SBIG was not selling EF to T-thread adapters, but only Canon FD to T-thread. Of course, most Canon tele-primes 100mm or longer focal length do not need closing down for astro anyway.
Perhaps if you say what lens/OTA, precisely, you are trying to mate to what camera, you may get a more useful answer. Best wishes.
#8
Posted 15 January 2011 - 11:45 PM
http://cgi.ebay.com/...=item2eafad016c
#9
Posted 20 January 2011 - 02:31 PM
I'm planning to use this as a light quidescope and will update again to let you guys know how it performs.
By the way the extension tube comes with 3 spacers so you can combine them and get the spacing about right.
#11
Posted 21 January 2011 - 08:59 AM
#12
Posted 22 January 2011 - 03:14 AM
#13
Posted 23 January 2011 - 12:54 AM
#14
Posted 23 January 2011 - 10:37 AM
#15
Posted 24 January 2011 - 01:35 AM
