HEQ5 Pro Synscan and USB port
#1
Posted 06 June 2011 - 06:51 AM
Hi want to connect my Synscan on a computer that has not a serial port. Is the pinout of an adapter like this can do the job ?
Thanks very much for your help
#2
Posted 06 June 2011 - 07:16 AM
It is for EQMOD type of arrangement, bypassing the handbox?
Actually it needs a USB (slave) <--> RS232 at TTL level adapter, if the cable goes directly into the intelligent motor controller.
Commercial USB <--> RS232 adapter sends out the common RS232 level, not TTL level.
Clear Skies!
ccs_hello
#3
Posted 06 June 2011 - 07:38 AM
No, I want to control Synscan with a planetarium Software like StarryNight Orion Special Edition. I have the original serial cable
#4
Posted 06 June 2011 - 11:29 AM
CCS_HELLO,
You must have a USB to serial adapter cable on the PC side.
#5
Posted 06 June 2011 - 05:27 PM
If your PC is going to connect to the handbox (right hand size RJ11), then a serial cable with RS232 level is needed. The wiring for the 6P4 RJ11 is here.
A USB <--> RS232 (probably like yours) will work, so long as it is supported by your computer's OS version.
Clear Skies!
ccs_hello
#6
Posted 07 June 2011 - 09:44 AM
Andre,
Clear Skies!
ccs_hello
Thanks, I still have this cable. I will try the adapter Serial -> USB soon.
Clear sky !
#7
Posted 07 June 2011 - 09:43 PM
