Tired of waiting! I need Eyepieces
#1
Posted 15 December 2013 - 07:40 PM
Well it's been months, and they have never come in stock, and I have yet to try my new Binos. Is there something else for about the same price, that will give the same performance per dollar? Should I give in and just get the 20MM version of these Sterlings?
#2
Posted 16 December 2013 - 04:37 AM
JMO
Matt
#3
Posted 16 December 2013 - 04:41 AM
#4
Posted 16 December 2013 - 09:17 AM
The problem in the C11 will be that the true field will still be less than what you can get in mono-vision, so you will find yourself wanting a wider field.
Also, a 20mm pair may simply give too much magnification to be useful in the C11. If you don't use 280x a lot, then you won't get much use from the high power position.
I have to say this too. The D21s really are the best possible eyepiece for the Denks. The field stop is perfectly matced to the apeture of the low power arm, so there is no vignetting, and the focal lenght is 21.6mm, so not terrible in terms of magnifiction even in the C11.
Then at least you would have one pair of eyepeices that
#5
Posted 16 December 2013 - 10:27 AM
I concur with the Agena 20mm SWA 65° at a mere $33 apiece. They are my favorites for planetary and double stars. MikeGo cheap….but quite good. Agena Astro WA 12 17 and 20mm. Or AT paradigms or other clones even better. Or ES 16 20 24 pairs before ES puts up the prices!
JMO
Matt
#6
Posted 24 December 2013 - 01:36 AM
...Ralph
#7
Posted 24 December 2013 - 11:45 AM
I give up. After doing some reading when I got my Denk 2's, I decided To go with a set of 25mm Sterling Plossl eyepieces. Looked like a good choice for reasonable eyepieces a Decent FOV, and at a great price.
24mm panoptics, or the lowest power 24mm 68-70AFOV 1.25" eyepieces you can get for widest TFOV.
#8
Posted 24 December 2013 - 02:35 PM
Sorry you missed them as I think you would have been pleased. I ordered mine a year before I got my binoviewers in anticipation of a future purchase. Turned out to be one of my better decisions as I am truly pleased with the views.
As mentioned above there are many good and (perceived) better alternatives.
But, some day I would really like to try out a pair of D21's and 24 Pans just to see if the difference would have been worth the 7x cost.
BTW, the actual FOV of the 25 Sterlings is equivalant to that of the D21's. 25 with 58 degree AFOV vs. 21.6 with 65 degree AFOV. Both (I presume with the D21's)with a sharp field stop in the Binotron 27's.
Eric
#9
Posted 05 January 2014 - 03:55 PM
#10
Posted 10 January 2014 - 02:52 AM
#11
Posted 10 January 2014 - 03:29 AM
