A few years ago I purchased the last three 60/1000 Carton optical sets and three NOS Carton threaded tubes from Apogee's Sheldon Faworski, and the last few Chinese 1.25" (6-inch draw tube) R&P focusers from now-defunct Meridian Telscopes, and assembled three "new" 60mm f/16.7 achromats out of old, but unused parts. Classic components, but never assembled together into telescopes during the Golden Age hence not precisely classics.
At any rate, this afternoon I finished artificial star testing all three using a green filter, identified the best of the three OGs , disassembled and cleaned the optics, and reassembled the OTAs, placing the best OG in the best condition tube assembly. I now have what I deem to be a 60mm wolf in sheep's clothing.
But there's a hitch. First off, the OTA is not drilled for mounting a finder scope. Second, one of the OGs has a spacer that is clearly thicker than the rest. With respect to the finderless nature of the scope, I would like a finder. I could drill holes and use bolts to mount a finder shoe to the OTA, but instead am thinking I'd rather have a peep-sight like the ones use on Zeiss Telementors.
Example: http://whuyss.tripod...telementor3.jpg
So I'd welcome suggestions regarding what I could use for the peep holes (I was thinking some kind of hardware fixtures used to hold rails or racks might work. Perhaps cruder, but simpler, I could simply cut some small diameter tubing to make two "rings". I'd rather not drill, so am looking to attach with some form of adhesive. So what's I'd like beyond suggestions of what I could use for the rings on what I ought to use to affix them to the tube and. crucially, how I should go about aligning them mutually and with the center axis of the main scope's optical pathway.
- Jim
