I've had little time to work on the telescope project but I did manage to get the mount design refined a bit. I also managed to make a wooden bearing, just to see if it would be sufficiently functional. It did work OK but I realized that wooden bearings were not going top provide the kind of smooth, quiet action I want for this mount. I started looking at steel bearings and found what I would need was going to cost around thirty bucks each making the total cost of the just the bearings around $250 plus shipping (ouch!) Then I discovered AliExpress, kind of a Chinese version of Amazon and found the exact same bearings for a total cost of seventy bucks including shipping!
The only issue was the interminable shipping time.
I redesigned the mount around the steel bearings, a radial needle roller bearing and a flat thrust bearing at each end of the two shafts. There are also numerous small changes in the design which simplify the construction. I will add some locking screws and setting circles before I'm done with this!
The jpeg is too small to see the details as the original drawing is done full scale. If you are interested, a full sized PDF version can be seen here:
http://www.daviddecr...isc/mount_2.pdf
Would be most interested is any comments or advice and I will be posting progress shots as I go.
