Saturn with spots - Dec. 31, 2010
7 replies to this topic
#1 idp
idp
Posted 01 January 2011 - 06:04 AM
Hi to all,
I haven't posted for a while because of little or no observing, due to (too) many moves. However, I got a chance to observe Saturn for a couple of hours on yesterday morning under excellent sky and would like to share this sketch. I observed near Verona (Italy) with a Newton 200/6, time of the sketch is 05:35ut. Transparency was excellent as was seeing (II in the Antoniadi scale), but heavy light pollution.
A bright spot in the N temperate region was clearly visible at 240x, but one tended to "lose" it as one increased powers in order to see it a bit better. Brightness and contrast must have faded a lot since Dec. 19, when David Gray estimated the brightness of the only spot then visible at -1 on BAA scale (that is, out of scale!) and easily seen in a 3'' refractor. It was still the brightest feature on the planet, with a distinct white colour as opposed to the yellowish globe and brown bands. Contrast was better with a blue filter, worse with a yellow one and much worse in red light.
I had my best views of the spots at dawn, while Saturn barely "breathed" at 360-500x. I was almost frozen, but it was worth it - as always.
Happy new year to everybody!
Idp
#2 Jef De Wit
Jef De Wit
Posted 01 January 2011 - 07:06 AM
Wow! Beautiful sketch! And thanks for the information about the colorfilters. I hope I can catch the storm myself, but every morning when he's visible, it was cloudy.
#3 VikingRaider
VikingRaider
Posted 01 January 2011 - 07:28 AM
Awesome sketch and thanks for the invaluable tips with the filters---I have nearly the same setup (200mm/f6 reflector) and it's cooling outside as I type this. I'm hoping the clouds hold off long enough for me to check out Saturn before my son wakes up...I have a tight window and fumbling with filters would have eaten up valuable moments of observing. I'll check it out with the blue now and see what happens!
Awesome sketch!
#4 Heidescoper
Heidescoper
Posted 01 January 2011 - 08:25 AM
hi,
great visual observation !
ThankĀ“s for the detailed information. I`am now electrify ;)
I try to catch at the next opportunity a view on Saturn in the morning time ...
CS
Christian
#5 Rutilus
Rutilus
Posted 01 January 2011 - 08:42 AM
Great sketch of Saturn.
Gives me hope of getting a clear view of the storm.
#6 Special Ed
Special Ed
Posted 01 January 2011 - 09:54 AM
Ivano,
Thanks for posting your excellent sketch and observation. I hope the storm stays relatively bright for a while so we visual observers can get a good look at it. The trick is arranging for a clear sky at the time the storm is in view--quite a trick for many of us this winter...
#7 dweller25
dweller25
Posted 02 January 2011 - 02:56 AM
Excellent drawing and observation. I am still waiting to see the storm !!!
#8 frank5817
Posted 02 January 2011 - 03:03 AM
Ivano,
This is a wonderful sketch of Saturn showing much detail.
Happy New year to you also.
Frank :)
